FF problem
McDoc
i have installed u-torrent avast anti-virus.the problem is when i shutdown firefox. than i switch off the monitor for power saving and the cpu is running and movie is downloading on utorrent so after some time when i switch on the monitor it automatically opened a website which i did not visit. please tell me what to do
Well we could have helped you but you messed it up:(
Forum Rules
1. Posting/discussion about software cracks, serial no's, and illegal downloading and duplication of software is prohibited.
Next time leave out you're pirating and we will be able to help you:)
You are infected because you are using a file sharing program (utorrent) and who knows what else you might have installed (bearshare or limewire?)
You need to uninstall such software so we may help you clean your system.
You need to scan your computer for malware. Follow this procedure.
Please download Malwarebytes' Anti-Malware from here, here, here or here and save it to your desktop.
  • then click Finish.
  • If an update is found, it will download and install the latest version.
If you continue to experience problems after doing this, please post a HijackThis log by doing the following:
isn't that jumping to conculsions a bit ? I see that quite a bit on here, someone says they are downloading a "movie"...but that doesn't necessarily mean that they are downloading a copyrighted "movie", there are plenty that are made to be shared via torrent sites :)
Maybe but I doubt very much that he is downloading a non copyright movie. Not very many people out there use torrent sites for legal things. Rather he is or isn't there is no way of knowing so he shouldn't mention it at all.
True, but I would rather see someone get help than be denied because they put "downloading a movie", it's not as if they are discussing what they are downloading or how to download it etc...
