Basically I'm having a controversy here... which to go with.
I'm getting all sorts of different answers from different places, why one is better, why the other is etc. And I was wondering if I could get some quick advice on which you personally find to be a better buy and why?
I'm going to be using this comp mainly for gaming/partial autocad use for business. Other specs will be as follows.
- Intel i5 750
- G.Skill PC3-12800 4GB 2X2GB DDR3-1600 CL9-9-9-24
- OCZ 500W PSU (May increase)
- ASUS P7P55D
- WD 1TB
Gaming will most likely run in 1920*1200 max resolution. I have a 22" CRT.
For the price difference is it really worth getting the 5770 over the 4870? I've heard the 4870 performs just as well and is generally $40 cheaper.
Thanks for the help in advance.
- Intel i5 750
- ASUS P7P55D
- WD 1TB
