Computer Cases
Sarcastically: Yah, I agree with Matthew... airplane hulls just take too much time to build, too, I mean, it's just a big container!
The case costs as much as 4890....enough said. I wouldn't even buy if I had money for it, I'd go for Antec 902.
If you went and had a crap load of money, like a huge amount, would you not get a bitchin' case just for the hell of it, for cooling and for damn good looks?
Id love the CM690 II a lot more if the tooless was optional. I love solid metal to stop vibrations etc and the front 2 120mm fans from the Antec 900 to be honest.
The rest of the case is fantastic though...love how its all pre-cut and stuff which should be mandatory on cases over $80 :P
try a CM 590
better than a 690, as it has better layout for airflow, but slightly worse for cable management, as the HDD's connectors are facing the back of the case, not the side...
i have one, and my temps are brilliant. Sit and think about it, and you can manage you cables in an awesome manner (i hate that my P965 mobo has the mobo connector bottom left of the CPU cooler...)
yeah the centurion
its a solid case
i really love mine. Im getting better results than a HAF 932...
I just wish i could find proper dist filters, cause after 6 months, i neeed to give my computer a clean (but the front filters included to quite a good job)
I always clean my 900 every month or so....what is odd is up north I didn't have to clean it but once every 6 months and even then there was little dust.
Now in the south I have to wipe my front panel off every 2 days and whats worse is I clean this new place better :/
