What is the best pc case for...
lemon07r
What is the best pc case for x3 5770s, sound card, 4x 2gb ram, x3 hdds and a H50 cooler. Im a little picky, I need good reverse airflow (for H50), and I'd like some thing with a tiny blue (like lights). Price range is $40 - $160.
Yeah they are good, move a reasonable amount of air. The reviews also say that it has good cooling. Good choice :)
From what I can tell off New Egg's website, 3.
Cooling System
120mm Fans Rear: 120 mm fan x 1 / 1200 RPM / 17 dBA
140mm Fans Front: 1 x 140 mm Blue LED fan
Top: 1 x 140 mm fan(supports 120 / 140 mm fan x 2)
Yeap, I just wish the ones that came with my 690 were less loud! :mad: But don't let that skew your judgment. :D It's still a great case, but now I need to switch a fan out. Honestly, when your gaming, you won't notice it at all if you get a "loud-ish" fan. It's not even that loud, just that my ears are more sensitive to sound.
What about the CM Storm Scout or Sniper? The Scout is big enough for almost anything already, the Sniper just adds to it!
the cm690 20.65" x 8.39" x 18.98"
the cm690 2 20.80" x 8.40" x 20.10"
not sure if that couple diffrent measments would make a diffrence
