El Gappo
http://valid.canardpc.com/show_oc.php?id=957385 < should be 5.2 dammit. Still not bad for 5 minutes works.
God I love this thing, The metal retention bracket was to small btw so I just drilled this plexiglass out
I couldn't afford itbe a man and go cascade(who care's about noise or energy consumption
) nice unit though
Yeah that's just the power connector from the psuWhat are the two runs of what looks like 8 guage wire for that are plugged in next to the cpu? Are they power for the processor? If so thats nuts. Sweet setup post some final results when you are stable and at the ceiling.
I have wire like that in my truck going to my front and rear stage amps coming off a fuse block with 4 guage that comes off a fuse block with 0. That is alot of power are you going to use it like that all the time? What I mean is are you going to check your E-mail and surf the web after playing some crysis with it OC'd like that?
