BF2 Freezing
awildgoose
Alright, so I don't know why, but my computer just will not play BF2.
I load it up, everything is fine until I load up a map. I load it up, I go to choose a class, but I can't because my mouse will not move, not at all. I've looked at everything in the options, my mouse is defiantly setup right in Bf2.
Can anyone help me?
Please?
Oh and my mouse works perfectly until I load the map.
The problem currently has happened to me, this is the second time that this has happened...here is how you fix it:::
1. Go to My Documents
2. Click on Battlefield 2
3. Click on Profiles
4. Locate which number your Login is, for instance : the first account listed when the BF2 login screen comes on would be 0001 .. do not open it yet
5. Click on one of the other profiles, or the default one
6. Then click on Controls .... notepad should come up
7. Highlight and then copy all of the information in there.
8. Then go back and find your profile, and click on it
9. Then click on your Controls
10. You will notice it is empty, thus ...
11. Paste the copied material into the folder, save, and then you're good to go
Source:
http://www.hardwareanalysis.com/content/topic/50101/
Yea I fixed what the problem was. The mouse settings in-game were changed (what moved the mouse was taken off of x-y axis), must have been an accidental mouse move I hadn't noticed while changing controls.
Thanks anyway Nev:good:
good man,Let me know when you get BF:BC2,we should battle together....thats if you dont ping out on me :P
