Hey all, not been on here in a while
Just wonderign what GPU should i get?
I was thinking of 2 x 5770's in Crossfire? or a single 5870?
I tend to play a lot of games and i do web design aswell
I have a budget of around £250
Thanks guys!![]()
Please show me where you can get a 5870 for less than £250, I can't find any online
although the 2x5770 will probably cost more than a single 5850, they are more powerful. If I had your money, I would be going with them over a single 5850, even though 1 5850 has the upgradability of sticking a second one in there, once you have the money for a second, you will probably be able to sell on the 5770's to cover the costs of another 5850, so it will all work out the same![]()
what's the point in that? higher clocks different name? I don't think they're going to do that xD, it's like making a gtx299 because it has higher clocks than the gtx295 xD
EDIT: This is where i can find the cheapest 5870! LINK![]()
But isnt that what card series do? They go up in name as they release a better performing card..? In your case you just said it would be the 310 aka Fermi..
£300 including VAT..then probably delivery on top
damn.
I suggest sticking with a strong single gpu, microstutter is really annoying.
can i ask what game your 4890 cannot handle on high settings? because ive failed to find a game that does not run on very high settings with my 4890...its a beast.
But if you realy want a new GPU.....wait for the fermis but i think they will be very pricy!
I'd be going (and will be) 2 x 5770 in xfire. Perform better than the 5870.
i thought the hd 5770's in crossfire fell just short of the hd 5870...
I always thought 5770x2 ~ 5870 in performance... guess I figured wrong, eh?
