I know that pci-express x16 cards can be place in an x1 slot, but can you do the same in an x4 slot?
No you cant. Not unless you saw the back of the slot out. An x1 slot is inches shorter than an x16 slot. But yes an x16 card will fit in a x4 slot.
You did, but it wasn't as straight forward.Thought I cleared that up in post #4....except the part about using a 1x card in 4x or 16x. You can also use a 4x card in a 16x slot too haha.
What board do you have?
Well taht is interesting. I have never seen that before, and thus I stand corrected. (I am actually sitting... Under a leopard print snuggie...)
Depends on the card, and is the x1 and 2.0 or 1.0 slot?
With a 5870, a 1x 2.0 slot still gives 75% of the performance of 16x.
