Theblackoutow
I was wondering if I should get a 120 side fan for my Antec 900 case, if it would help cool stuff down some. Also if it should blow air in or suck it out, which would be best.
120mm fan as intake on the side is a good idea, will provide cool air to the motherboard chips, gpu and cpu.... You will then have 3x120mm fans as intake 1x120mm 1x220mm as exhaust, should create a nice airflow
The 120mm exhaust is best. The GPU blows hottest, blowing hot air on it just circulates the hot air, not get rid of it.
Not just a guess, i have the 900 and tried both ways, intake kept it at same temps, exhaust was -5*C on the card on moderate/heavy loads.
