New Build..Opinions
Laquer Head
Well-Known Member
I had plans for an HTPC, but I abandoned it before xmas and have chosen to now make a full PC.
So I have acquired a few parts and have some already here to finally start a new PC build.
I'd just like a little input/opinions what you all think!
Already Have:
-26" Asus 1080p LCD panel
-CoolerMaster Cosmos Chassis
-LG BluRaY
-LG DVD-R/CD-R..etc
-Logitech WiFi Keyboard & Mouse
I Need the following and have tentatively picked these for purchase...(opinions)
-MotherBoard - Asus P7P55D-E Premium Intel Core i3/i5/i7 Intel® P55 - LGA 1156
-Processor - Intel Core i7 860 quad core
-Hard Drive - 2TB Seagate Barracuda XT Sata 3.0 6gbps
-Graphics - Sapphire ATI 5790 1GB DDR5
So I wanna hear opinions on these components working together,
I need opinions on PSU & a CPU Cooler!
Thanks
looka prety damn good, i really don't have anything to add.
I am jealus about that 26' monitor tho.:P
Umm, im not sure what a 5790 is?? but the build looks amazing so far.
For a graphics card, since a 5790 doesn't exist, Get a 5770 or 4890 for $170 or if you want great performance/future proof, get the Asus 5850. It can be overclocked past a 5870 and still stay under warrenty thanks to Asus' Voltage tweak =]
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121361&cm_re=5850-_-14-121-361-_-Product
For a PSU that can run that rig and any of these Graphics cards, go with corsair. GREAT reliability and performance. Im using one as well.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006&Tpk=corsair 750
This psu can only crossfire the 5770 because the 4890 and the 5850 use 2 pci express connectors. But that's not a problem because if you get the 4890/5850 they will be more than great dedicated cards.
Im not sure of a good heatsink for your cpu :(
Good luck though and hope this helped :good:
:confused:
Agreed with Corsair for power, and do you have RAM, yet? I'm not sure on what CPU cooling as I don't own any Intel builds :P
I'd also like to ask (if you don't mind my asking,) what you do for a living so you can buy a 5970 and still afford to clothe and feed yourself? :D
Yeah, I'm stuck on RAM too..lol
I'm a safety officer with a major North American construction equipment manufacterer.:)
@Stoic - he said 5790, you said 5970... not sure if one of you mis-typed
How bout something like this?
CPU- $289
Intel Core i7 920
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
Mobo- $192 ($20 rebate)
ASUS P6T SE LGA 1366 Intel X58 ATX
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131386
RAM- $140 ($20 rebate)
OCZ Gold 6GB (3 x 2GB) DDR3 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227365
Hard Drive- $55 each
2x Samsung Spinpoint F3 500GB (verrry fast)
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152181
GPU- $208
XFX Radeon HD 4890 1GB (Double Lifetime Warranty)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150438
PSU- $110 ($10 rebate)
Corsair 750W
Heatsink- $85
Noctua NH-U12DX 1366 120mm SSO CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608012
Total- $1134 shipped, after rebates
Do you need an OS?
Windows Pro 7 64-bit $140
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116758
or try this mobo for $220 ($20 rebate)
EVGA 1366 Intel X58 ATX SLI LE
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188049
The reviews on the Asus boards below this one ^ have a surprisingly high rate of DOA or RMA issues. Also read bios updates needed. they're probably fine but people review when they're pissed off...
$192 http://www.newegg.com/Product/Product.aspx?Item=N82E16813131386
$233 http://www.newegg.com/Product/Product.aspx?Item=N82E16813131359
How close was I to your budget? if you post it, we can zero in on it. I haven't seen any ballpark figures. I just tried to do the best i7 setup on a lower budget
Good rig, although are you going to need as much as 2TB? 2x 500GB will be better I guess
I'm gonna use a SSD for my o/s and the 2TB storage--I'm going with it as its SATA3 6Gbps
Yeah! I mistyped! I meant sapphire ATI 5970
Do you need an OS?
Nope!
I'm not really on budget! I just need to buy the parts I like!
I'm liking the new P7 boards from ASUS as they have usb3 and sata3,
