what are you saying like speed vs size? depends but if you are talking performance then speed obviously.
well the higher the rpm the quicker the drive read speeds etc all laptops and ssds are 5400rpm, most desktops are 7200rpm although you can buy 10,000rpm raptor drives, but these are obviously noisier.
no larger buffer would give you better read times the hard drive will basically cache its common files in its buffer and then you can access it faster than seeking it from the disk... its like the hard drives on RAM.... this file being so small would benefit more on an OS drive buffering the smaller os files that it uses a lot.
"ssds are 5400rpm?"
tell me what spins 5400rpm in a ssd when there is no moving parts?
Well, sort of,you mean the buffer being there makes a big difference in the cpu? I am not sure... difference perhaps..big probably not. you figure the cpu still has to process the information either way. I dont foresee a drive with a 16MB buffer performing circles around a drive with 8MB... But the price difference is minimal so you might as well go for it.
or did I misunderstand you?
From my understanding on this ( i dont study HDD facts all day or anything ) write no, read yes but nothing to brag about. i mean its a 16MB buffer.... I have mp3's bigger than that.
