Need to build a new computer
smkelly1
I have not been in the desktop computer scene for a while. I want to build a system that is Intel based, has decent sound and is pretty quick. I have built numerous computers, but it was at a computer shop over 4 years ago. Any help would be appreciated.
well you won't need that :) what do you think of the build then?
Looks good. I would like to get a Gigabyte board, dual hard drives for backup purposes as I deal with alot of finances and pictures. Also would like to get a BLU-Ray player/burner. Should have said that at first.
One thing I didn't notice is Linkin93 forgot a power supply with all his components. Here is a decent power supply. I have this one in my present system and it has served me well:
OCZ StealthXStream OCZ600SXS 600 Watt Power Supply - $75
http://www.newegg.com/Product/Produ...=ocz_600w_power_supply-_-17-341-010-_-Product
Also if you wanted to save a little money on purchasing two hard drives you could go with two 320 gigabyte hard drives instead of the 750 gigabyte hard drive:
Western Digital Caviar Blue WD3200AAKS 320GB - $50
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136074
I would avoid OCZ DDR3 RAM. I have heard bad information about the quality of OCZ DDR3 memory. OCZ DDR2 RAM is good quality, but I know you are not looking at Double Data Rate 2 memory.
Take a look at some of this Patriot DDR3 memory:
Patriot Viper 4GB (2 x 2GB) 240-Pin DDR3 1333 (PC3 10666) Dual Channel Kit - Retail - $104
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220372
Th Phenom II 955 Processor is really good quality and less expensive than the Phenom II 965:
http://www.newegg.com/Product/Produ...m_ii_955_black_edition-_-19-103-674-_-Product
You are very helpful. Thanks.
