Anyone have this monitor?
Are you sure that you want to get a monitor that only goes up to 1680*1050 resolution? You probably want something that goes up to 1080p. If you're going too be seeing it at a distance while watching TV, though, I guess that it would be fine, since you wouldn't be able to see the full 1080p anyway. Other than that it seems like it gets very good reviews, which would be the deciding factor for me.
I have this monitor: http://www.frys.com/product/5872253
Honestly I think a 22" with a 1680x1050 resolution is a cheap (as in low-quality) product considering the measurements. The monitor that I have is:
1. Cheaper (as in cost)
2. Has an incredibly high contrast ratio
3. Is very bright and has excellent colors
4. And has 1080p video (1920x1080 resolution)
I would advise you to go with something better than that monitor (like the one I have :)), unless you need HDMI inputs... (You can get an adapter (DVI -> HDMI)for cheaper than getting to other monitor though)
Soo, I dunno, go with what you like. I'm just making a suggestion.
I NEED a tv tuner. My tv is a piece of junk and not far from dying. My computer is in my room in my apartment so the furthest I'll ever be from this thing is like 10 feet.
Looked up quite a few reviews on it and it's nothing but good reviews on it.
Do it then. It looks like a good buy.
The resolution doesn't really matter anyway since it's only 22 inches. Looks like a pretty decent monitor/tv. I would get it.
