Looking for Auto-Shutdown program
Bacon
I've found some via google, but none had the one major quality I was looking for. Which is that it gives you something like 30 seconds to suspend the shutdown for an hour or thereabouts.
Not sure what you are looking for..
I use a timmer to shutdown or suspend the computer.
This one that i use:
http://download.cnet.com/Switch-Off/3000-2344_4-10056977.html
But i think that isnt what you are looking for?
Looks like most of the other ones I was looking at. Only thing missing is the ability to suspend the shutdown.
Dunno if this might help, but an example would be like I set the program to shutdown the computer at 11pm, but I'm still using the computer. So I want the program to ask me if you want to shutdown and if there is no response within..say 30 seconds, it'll shutdown.
Hopefully that makes what I'm trying to ask a little clearer.
