Windows 7 Taskbar help please
Mikeohioukus
Hi all, i have a simple question about the Windows 7 taskbar.
I just launched Microsoft Flight Simulator X and the taskbar has gone from being transparent to solid, I don't really like the change, Does anyone know why this might of happened and how i could change it back?
I'll appriciate. any help. Thank you.
Does it go back to normal if you reboot?
I have not tried that yet as i set a flight up on flight sim, I'm guessing it may go back to normal if i reboot..
However there is another question i have, its slighty of subject but, I just recently got Windows 7, and when using Internet Explorer 8 i notice that if i mispell something for example in this box here, nothing changes, no red lines underneath show its incorrect, I think when i had vista it used to go red and i could right click it and select the correct spelling. Would you happen to know what i could do?
I don't know, I run XP. But most likely it was some software that was loaded after the fact, I have vista on my laptop and I haven't seen it there either.
