Finally have all of my parts...Ready to build??
Elohssa6
So I have slowly bought everything I need....Can someone look this over and tell me where I went wrong??
The computer will mainly be an HTPC, but I plan to also use it for some other simple desktop functions.... I have posted about this build before, but I just want a last minute look now that I officially have bought everything.....
Here is my list of hardware:
CASE:
nMEDIAPC Red Wood Wood/Steel HTPC 8000 ATX Media Center / HTPC Case
LCD for CASE:
nMEDIAPC PRO-LCD Media Center Programmable LCD
MOTHERBOARD:
Intel BOXDH55HC LGA 1156 Intel H55 HDMI ATX Intel Motherboard
CPU:
Intel Core i5-660 Clarkdale 3.33GHz LGA 1156 73W Dual-Core Desktop Processor Model BX80616I5660
RAM Memory (2x4gb):
GeIL Black Dragon 8GB (4 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10660) Desktop Memory Model GB38GB1333C9QC
HDD (2T)
Western Digital Caviar Green WD20EADS 2TB SATA 3.0Gb/s 3.5" Internal Hard Drive
BluRay/DVD:
LG Black 8X BD-ROM 16X DVD-ROM 40X CD-ROM SATA Internal Combo LG Blu-ray Reader & 16X LightScribe DVD±R DVD Burner
POWER SUPPLY:
CORSAIR CMPSU-400CX 400W ATX12V V2.2 80 PLUS Certified Compatible with Core i7 Power Supply
KEYBOARD/REMOTE:
Gyration GYR4101US Black 2.4GHz RF Wireless Mini Air Music Remote w/ MotionSense & Compact Keyboard
WIRELESS ADAPTER:
TRENDnet TEW-623PI 32-Bit PCI Rev. 2.1/2.2/2.3 Wireless N-Draft Adapter
The 2 things I dont have are: The thermal compound and the OS.....Should I buy Windows7 from newegg or is there a better place??
Am I missing anything?? Is everything compatible? Before it all goes together, would you change anything??
I guess I am now ready to build...
What do you think??/
hmm, yeah. get some thermal compound and start building :)
if you already have everything, no point in changing stuff now, but it looks like all will work.
you should have bought an oem os when you were buying parts, if you buy retail you will pay more. if you're a student, some schools sell the os for cheaper, you might want to try that.
I can still buy the OS from Newegg...Or try my schools bookstore....
Thanks for the help.....
Try your school. I got my Windows 7 for free since I am a computer major, and I heard other student get it for a really good price also.
