Use the foamwait weren't you one of the anti caseless crew?
*evil glare*
get the cm case take the back panel off and mount your mobo the wrong way
instant techstation.
hell no, im always for casless. i dismantled my old case, took out the mobo tray and put my mobo in that, and put that on the foam. my temps are better than ever, GPU maxes out at 56c. but my friend is selling his CM elite for $20, im probably gonna go pick that up, or build a stand out of wood so my pc isnt on the ground
Isn't that what meticadpa did with his setup? Looks like it works well enough.
No I think he just took out the mobo tray ( he isn't as creative as this) Im talking about putting everything in the case as usual then putting it on its side and mounting the mobo on top
I'll have to have a go and post a pic, cheap techstation ftw :good:
Here is my caseless setup as it stands http://img180.imageshack.us/gal.php?g=dsci0157s.jpg on a cardboard box with foam on top. the box is only there because it was to low down for me to reach the reset jumper across this stupid table. Check the 5.3" tower lol. I'm making a techstation soon, it's to unorganized even for me and the vaseline is purely for insulation purposes to preempt any snarky remarks lol.
Just noticed you can see my cm v8 box in the backgroundthought you'd like that ganzey
Man.. I don't know how you can let your computer be like thatI'd be afraid to come home and find my cat stuck on top of it cause he got his fur in the fans..lol
Or find your cat has pissed all over it but that's another story involving a classified![]()
Nice uh Vaseline you got their, use that for easily prying in your equipment?
Vaseline in and around the socket or its gonna get real wet and blow up, nothing kinky. Cant beat bum lube tho.the vaseline is purely for insulation purposes to preempt any snarky remarks lol.
