Ps3 headset
A headset would be a good idea although I'm not exactly sure I would recommend USB. I have a Creative Fatal1ty USB headset and I usually get problems with audio drivers on my computer.
ill probably go with the clearchat thanks!
I would suggest you to get a headset that was made by a well known company because for the quality of the sound. It will probably cost you a bit more but at least you are getting a good headset.
If you want to not only hear them coming, but hear which direction, you're better off with a gaming headset. The ones you posted look like headphones for Skype and stuff. But if you get a gaming headset, you can hear if they're behind you, next to you, ect.
I use the one I got with SOCOM. I sold SOCOM because I liked the PSP versions better, but I kept the bluetooth headset ;)
