AceSpade77
Hello, I have two Nvidia Geforce EVGA GTS 250 cards running SLI, Direct X 11, and PhysX.
But i would still like to push the cards a little more, because I am only using a 23" inch monitor and im running sli, so that simply means im using two decent cards to make a good picture on a pretty small LCD. and sinse im in SLI mode the GPUs are splitting the work load, So all in all I think i can safley push a little more out of my two GPUs because i also have a 200m fan on them.
If you know how I can properly overclock these cards please reply (I am using a M4N82 DELUXE motherboard with a 3.5ghz cpu) , Please do not tell me to use Amd overdrive becuase that is for a lower series motherboard and my pc will not run it.
My current idle Gpu temp is 34c for both cards, on good games maxed out they run around 55c
Thank you for your help it is very much appreciated.
(Sorry for mis-spelling, i type fast)
