Which samsung monitor is best deal and why???!
Elkbugler
I have a syncmaster 245bw, 24 inch. I want to get another. My primary use is for Internet Poker. Anyways, can you fine people give me some honest feed back on which of these 3 monitors would be best buy, which would have best quality picture. Thanks
2494 SW Glossy BLack 24" 5ms, Widescreen LCD,
300 cd/m2
DC 50000:1 (1000:1) retail 209.99
2494 HM Glossy back 24" 5ms, Widescreen LCD
HDMI
300cd / m2
DC 50000:1 (1000:1)
Built in speakers retail 249.99
Syncmaster P2570
Glossy Black 24.6"
2ms (GTG) HDMI
Widescreen LCD
300 cd /m2
DC 70000:1 (1000:1) Retail 309.99
I have a Syncmaster, are they a better monitor?? THanks everybody
Honestly? Im not sure at this point i would go with a samsung for a monitor with a TN panel, as asus pretty much has them beat in that category. And if you want an IPS panel, nec has been pretty much always the way to go. Of those three though, the 2570 is most expensive because of its size, but picture quality between all will be pretty much the same. The 2924 is prolly the best buy there, if you are not totally commited to samsung though take a look at either of these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236082
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236081
2nd that
2924 is the better buy
Dont buy at bestbuy though
Stick to Samsung, Asus, or the higher end Acer's
iwas looking around and found a 27 inch LG (GTG) hdmi full HD, 1080p, widescreen LCD for 399.99shipped would this be a great monitor, deal. THanks
