help! confused.... pc3
jmandrumjunkie
can anyone tell me if the pc3 is conflicting with the graphics card sd ram.
2.53GHz Intel Core 2 Duo Processor
Cache
L2: 3MB
System Bus
1066MHz
Memory
Slots: 2x SO-DIMM
Type: PC3-8500 1066MHz DDR3 RAM
Installed: 4GB (2x2GB)
Capacity: 8GB main memory
Display
Type: Active Matrix Glossy TFT-LCD with LED Backlight
Native Resolution: 1280 x 800
Supported Resolutions: 1280 x 800 (native), 1152 x 720, 1024 x 640, and 800 x 500 pixels at 16:10 aspect ratio; 1024 x 768, 800 x 600, and 640 x 480 pixels at 4:3 aspect ratio; 720 x 480 pixels at 3:2 aspect ratio
External Resolutions: Up to 2560 x 1600
Graphics Display Card
Interface: Integrated
Installed: nVIDIA GeForce 9400M graphics processor with 256MB of DDR3 SDRAM shared with main memory
Internal Resolutions: Up to 1280 x 800
Dual Display: Yes
Video Mirroring: Yes
Storage and Expansion
Well, if it's already in there, it shouldn't conflict. I don't blame you, though, memory is a confusing field in computer-building and choosing. (Remember, more memory is NOT always better)
The memory on your motherboard and the memory your graphics card uses have nothing to do with each other. It will be fine!
indeed. thanks, i dont know how you can have pc3 ram, AND share sd ram from the vedio card. it says that it is shared and i dont know how it can share if it is two different kinds. im not very savoy
I'm not sure how it works either(as in the technical details) but I have built enough computer to know they don't interfere with each other in anyway. My own computer has DDR2 and my GPU has DDR3 and it runs perfectly fine.
