Don't see a boot up screen after installing Windows XP
j3c
I installed Windows 7 64 bit Professional on my computer, and then I created a partition through this method http://lifehacker.com/5126781/how-to-dual-boot-windows-7-with-xp-or-vista
I installed Windows XP Home edition on the new partition I created. Problem is now the computer just boots straight to Windows XP instead of showing an option like this
Edit: Found a second part to the instructions, so Ill try that out to see if it fixes the problem
Edit 2: Yep solved the problem :D That was scary
