RAM Compatibility Issue
tweaked9107
Hey guys, ive recently built a new computer and when i fired it up everything appeared to be working, but nothing would come up on the monitor. After looking through my motherboard manual i came across the MemOK feature which tests your RAM. This concluded that my RAM doesnt work with my motherboard. After doing some research i have found some RAM that my manual says is compatible, but there is a catch which i will explain once ive shown my system specs:
Asus P7P55D PRO Motherboard.
Intel i5-750 CPU.
XFX Radeon 5850 1GB Graphics card.
Corsair 750W PSU.
Coolermaster CM-690 Advanced 2
Samsung F3 1TB 7200rpm HDD.
RAM that is not compatible is the Corsair Dominator DDR3 1600MHz 4GB (CMD4GX3M2B1600CL8).
The RAM i have found is the OCZ DDR3 4GB 1600MHz (OCZ3X16004GK).
My motherboard manual says this IS compatible but here is the catch. It says, and i quote: 'P7P55D PRO Motherboard Qualified Vendors Lists (QVL) DDR3-1600MHz capability for CPU at 2.8 and 2.93GHz.' That is the list that the OCZ RAM falls under. So will it work with my 2.66GHz Intel i5-750. Or will it not?
My other question is will the RAM not being compatible mean nothing comes up on my monitor dispite all fans and lights working. Or is there another issue that is causing that?
Thanks.
It wont run at default Speed, to make it run at 1600MHz you have to run CPU at 2.93GHz
That's what I think, from my experience with i5 and DDR3. :P So don't slag me off.
