S.T.A.R.S.
banned
Well folks after some work,I finally finished small,but in my opinion pretty useful application with which you can install almost everything you need for your Microsoft Windows XP operating system from single DVD disk.All you have to do is to download the torrent from here:
http://www.sendspace.com/file/b92gbm
Then of course download the torrent contents which are about 1.5 GB in size then extract the file and then you will get one folder called "Microsoft Windows XP autorun" and one file called "HELP INSTRUCTONS.rtf".Now all you must do is to open that "HELP INSTRUCTIONS.rtf" file and follow the very short 8 steps written below and thats it!You will then have your own Windows XP DVD disk from which you can install the most common things that any home user might need.Also of course the disk will be bootable just like before.Also while you are installing things you need,you will hear nice music so you can just sit back and relax while the setup you selected does it's job.
Here is what you will see when you put the DVD disk in your CD/DVD-ROM drive:
The idea of something like this was to make some things easier to people so they don't have to search all over the internet to find few things and in the same time pick up hundreds of viruses lol.
NOTE 1: To make this program work,you must have 2 things installed on your computer:
--->Microsoft .NET framework version 1.0 or newer version
--->Windows Media Player verson 9.0 or newer version
NOTE 2: This torrent does NOT contain ANY cracks or serial numbers for the Microsoft Windows XP and therefore I have disabled the button called "Register the Microsoft Windows XP Professional edition operating system (5)".
Cheers everyone!If you have any questions,feel free to ask!
