Just Got parts, but have an issue
snowave6
So the parts finally came and i've assembled them. I still don't have the video card tho (and my mobo doesn't have any onboard video).
I wanted to put everything together so that when the gpu came i could plug and go.
This is my build.
* LITE-ON Black SATA DVD-ROM Drive Model iHDS118-04 - OEM57628732
* ASUS VE246H Black 24" 2ms(GTG) HDMI Widescreen LCD Monitor - Retail
* RAZER Lycosa Black USB Wired Standard Gaming Keyboard
* Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive57628732
* Crucial 8GB (4 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Dual Channel Kit Desktop Memory Model CT2KIT25664BA1339 -
* Intel Core i5-750 Lynnfield 2.66GHz LGA 1156 95W Quad-Core Processor Model BX80605I5750
* CORSAIR CMPSU-1000HX 1000W ATX12V 2.2
* ASUS P7P55D PRO LGA 1156 Intel P55 ATX Intel Motherboard -
* Thermaltake ArmorPlus(Armor+) VH6000BWS Black Aluminum / Steel ATX Full Tower Computer Case
plus an asus radeon 5970 when it gets here.
Problem:
The motherboard has a cool thing where it has LEDs by the parts that light up (maybe a lot have that idk) to let you know when there is something that isn't correct when booting up.
I followed the installation instructions very closely, but when i boot up, everything turns on good and stuff but then there is a red led light on the "cpu led" and then also on the "dram led".
Maybe these are just lighting up because i don't have my video card yet and its failing to boot because of that?
Edit: Oh, and also i needed an "Optical Drive Audio Connector (4-pin CD) and i didn't have one because my optical drive came OEM. Should most cases usually come with one ? Or should i order one?
Any help is greatly appreciated, thanks guys
Why would the computer case come with a 4-pin optical drive audio cable? If anything it would have come with the drive if they were still needed
I don't think you need those audio cables for the optical drives anymore, just the power and sata/ide info cable. I think they were used for analog audio from the drive to the motherboard when playing a cd? Just wait till you get the video card and see if the problem goes away. The computer is probably thinking what is the point in booting up if the user can't have an image to look at.
Wait...your computer has audio ports on the front...is it for those?
This is what the manual says about my Onboard LEDs.
"Post State LEDs check key components (CPU, DRAM, VGA card and HDD) in sequence during motherboard booting process. If an error is found, the LED next to the error device will continue lighting until the problem is solved. This user-friendly design provides an intuitional way to locate the root problem within a second."
The 'cpu led' turns red for half a second then the dram led turns red for half a second then the cpu again.
Then there is a green led that stays green in the bottom right corner of the mobo that says 'sb pwr'.
This happens when i turn it on and it only stays on before it shuts itself off in about 3 seconds.
I've taken out and reseating the RAM numerous times. I don't have enought time to hit the MemOk! button before the system turns off. The heatsink/fan is plugged in to the mobo.
Still shuts down in 3 seconds, with those red lights turning on for a half second each.
Edit: Have also tried only using 2 DIMMs instead of four in the a1 and b1 bays as the manual instructs.
Edit 2: I guess the manual says "stays lit" for the LEDs, and mine aren't exactly doing that i suppose. They are moving back and forth, and maybe its just going through routine checks (lighting LEDs) and then when it gets to the VGA, it isn't detected (since i don't have my video card yet) and its just shutting down because it cannot display an image. So maybe nothing is wrong, like Kon said?
I was talking about the audio cable...misunderstood the thread, sorry.
It's probably because there's no GPU in it or at least partially. Do the drives initialize?
Not sure what you mean by drives initializing..
All the fans start going, the LEDs blink at me, then the system shuts down.
If you have onboard video it should work, but you may get an error if the board needs a video card.
Another issue could be your RAM and CPU heatsink are not properly or fully seated.
Do the drives themselves make any noise? If they're doing something, that means the BIOS is operating.
Nope, no onboard video. Have checked and rechecked CPU Heatsink and RAM. Have tried redoing ram maybe 6 times including removing all but one stick.
I'm thinking it might just be because i don't have my video card yet.
I don't think the 'drives' are making any noise... it only turns on for 3 seconds. The main things i hear are the heatsink fan and the case fans. No beeps.
There is really no way of telling till you get a video card, nothing but assumptions if there is anything wrong or not. You did put the standoffs under the board in the right places?
Yeah, the standoffs are in the right spot. You mean the extender feet that go under the motherboard that the screws go into right?
MAaaaaaaaaaaaannnn, they moved back my shipping date for the asus radeon 5970 card to the 11th of march.. i dont' know if i'll be able to wait that long. They could move it back even further. Is provantage usually like this?
Thanks for the input guys, always appreciated. :cool::cool::D:D
You got a 5970? I'm jealous.
You could snag a cheapie from newegg if you can wait a week or two, lol.
I think I remember your posts. Fry's has the 5970 in stock for shipping at $649 right now if you are interested.
I think I talked you into the 5970 but things have changed for me. My second one went bad after we spoke and stopped clocking the second core. It worked fine for a while but then stopped working with no changes to the comp. My game rig only has one game and no software changed. This is the second one to fail on me. I loved the card but I can't deal with the problems. The first one was DOA.
I am sticking to the 5870 single card now, no more CF issues for me until ATI gets their stuff straight.
I read threads on fixing the 5970 second gpu not clocking but it takes the fun out of games if things are not reliable. I would not go back to the 5850 cf idea.
Hmm that has me worrying a bit.
Does anyone else run the 5970 that could have some input here? :eek:
Its basically in the mail soon, so fast responses are greatly appreciated!
I read a bunch of reviews on newegg. Seems the drivers have a fair amount of issues but they also say once you get them figured out it runs better than you could even imagine.
Reliability is big tho..
They just went on backorder for a while... i'm hoping its because ati is fixing their drivers, or something to fix the issues the 5970 is having. But it could totally just be because they are selling out really quickly.
It ran fine at first and it was everything I hoped for.
What bugs me is that the second card worked for a few days and then the second GPU would not get off idle. It also gave me a bunch of pink diamonds all over the screen. I didn't change or update anything from when it worked. I spent about 10 hours trying to make it work before I gave up. THe 5870 works perfect.
It sucks because I am dying to buy another one...
Haha... well that is so on the fence sounding! I'm like extremely excited but nervous... maybe i'll get lucky and get a good one?
/cross fingers, "Please don't be doa, plssss!"
I hope you get a good one also. If not I will feel bad since I pushed you towards it. Oh well, good luck and let us know.
Hey don't take blame, i purchased it. Plus there is no blame here.
I'll for sure let you guys know how everything turns out... I hate waitinggg!
:cool:
