how to identify dimm socket in my motherboard
hecxy
hi
please help me with this problem.... im wondering how to know what dimm socket do i have in my motherboard without looking the manual of the board.
is it possible to know the dimm socket by just only looking at driver cd of the board...
please help..
thank you in advance
hecxy
Leenis24
you mean the RAM slots, by what you call DIMM(dual in-line memory module). depending on the motherboard you have you could have 2,4,or 6 of these slots. all parallel to each other.
johnb35
Administrator
hi
please help..
hecxy
The easiest thing to do would be to give us the brand and model of computer you have if its store bought or the motherboard model number if its a custom built system. Then we can tell what type of memory you have installed. Or you can download a program called cpuz which will also tell you what you have.
hecxy
i have this board ASUS p5kpl-am-se
actually i know what ram do i have... i only want to know if it is possible to know what dimm slot do i have in my board by just only knowing the brand of my board.. is it possible? is there a shortcut method here....
johnb35
Administrator
It has ddr2 memory slots because you have ddr2 memory. Unless i'm not understanding your question.
xxartanisxx
Memory Type: DDR2
Memory Supported: 667MHz DDR2
800MHz DDR2
1066MHz DDR2 (OverClocking)
Number of Pins: 240-Pin
Number of Slots: 2
Maximum Memory Supported: 4GB
Max. Memory Supported Per Slot: 2GB
IDK what else to answer with haha?
Rit
Memory Type: DDR2
800MHz DDR2
Number of Slots: 2
I think that's it unless he can clarify his/her question :confused:
hecxy
thank you for all the reply
actually i know that information already..
i just wanna know if there is a easy one to identify how many pins are the dimm socket is.. by just only looking at the board personally.. or by just looking at the support cd. is it possible?
thank you again
hecxy:):):):):):):)
johnb35
Administrator
The support cd will tell you nothing about the memory slots. All you have to know is what type of memory the board takes and you know how many pins it is.
ddr2 is 240 pins with a notch in a certain spot
ddr3 is 240 pins with a notch in different spot then ddr2, so you can't interchange them
ddr is 184 pins with a notch in a certain spot.
None of these can be interchanged.
xxartanisxx
Memory Type: DDR2
800MHz DDR2
Number of Slots: 2
is what you have???
