massahwahl
So we are redoing our living room and I want to hook up my surround sound system to our television but we have a few obstacles. Heres what our TV 'area' looks like:
As you can see the TV and all of our peripherals sit inside that nook. I have previously had my HTPC hooked up on the shelf above the TV but it stuck out much to far and the cables for it were just a mess and it was impossible to run the surround sound speakers again due to how many wires are already back there. I mounted our wireless router and modem on the wall behind the tv and bundled all the cables nicely now.
So onto the HTPC situation. I am going to be moving it to the floor behind this chair:
As you can see there is already a white wire running along the baseboard (you can kinda see it), that goes to the modem behind the tv and it looks awful but I hope to alleviate all of my cabling issues. This picture shows you how close the chair is to the TV area, its roughly 4 feet to the bottom corner of the fireplace from where the HTPC will be not including wiring needed to follow along the edge of the fireplace molding up to the nook.
Now lets talk about my surround sound. I have a 6.1 system and I want two speakers mounted on the wall between the pictures and the molding (use your imagination where they will be) This area is to the left of the Tv and there will be a speaker sitting on the table:
And finally this is the right side of the nook where the other speaker will be mounted on the wall and one will be on the table beside the couch:
Another speaker will sit on top of the Directv box above the TV and I may mount the rear center behind the love seat on the left in picture number 4 or I may instead mount two on either side of the window.
The computer will be plugged in behind the chair and the Subwoofer will be back there with it. My surround sound system has all of the cables running into the subwoofer so the challenge is how in the world am I going to run all of these cables and make them look good? There is also a cable running from the TV sound output to the pc (Optical Out) and the video to the TV (S-Video) which need to be accounted for as well. I want to be as un-invasive as possible but I would be willing to replace the floor molding if there is an affordable option that would look good. My budget is around $100 and that includes purchasing the long S-video and Optical cable for the PC. All suggestions will be seriously considered so let me know what you think!
