Hjælp windows 98 start up disk!
scarmagedon
hej jeg hedder ib jensen jeg læser til it-supporter på svendborg erhversskole og en a opgaverne er at lave en boot disk til windows 98 og det er ikke problemet men den skal programmeres i DOS og der skal være en menu og jeg ville så lave en tast eller funktion så den åbned fdisk når man trykked på den tast! men kan ikke rigtig få det til a virke sætter meget pris på alle former for hjælp:)
..........:confused::eek::P
hi my name is Ib Jensen I read IT support for Svendborg erhversskole and a task is to create a boot disk for Windows 98 and it is not the problem but it must be programmed in DOS, and there should be a menu and I would then create a key or function as it opened fdisk when you pressed the button! but can not really make it a really puts much appreciate all kinds of help
.............:confused::eek::D
Google translate so we can guess what you're saying?
EDIT: Someone beat me to it. I'm deciphering the English translation now.
EDIT2: Someone turns out to be TFT. Bastard.
Alright. My response:
Apparently, what you're looking to do is simply create a bootable DOS disk with a way to open fdisk - however, I'm not exactly sure how you want that happening.
To create a bootable disk, all you need is have Win98/95/ME/DOS machine around and type "sys a:" (without the quotes) in the command prompt.
Since you need fdisk, you might as well copy that there too. The simples way to start is simply typing in "fdisk" at the command prompt after booting from the disk, do you actually need something more complicated?
What are you trying to do anyway? Are you simply trying to create a disk with tools to wipe out your HD and get a new installation going?
EDIT: Actually, never mind. You might as well download the disk from stranglehold's link.
