NO. I thought you could do a clean install with the upgrade version?
You can do a clean install with the upgrade disc?
Why wouldn't I be able to use the activation serial with the full copy. It's still W7, it's still the Pro version and it's still 64bit?
So what your asking is, if you have a upgrade installed. Can you enter a full key under Systems and make it a full version?
