Leopard drivers
Iulian81
Hi! Does Leopard Mac Os X have drivers? I don't find any...Also for games I found that almost all good games have Mac versions... These games don't need drivers on Mac or they work perfectly on Leopard and so I will not need drivers??
Leopard doesn't need drivers, every is almost always supported native. There are a few exceptions with third party.
Wow.. this is cool, but then how the games work? Don't they need some Directx or something...?
No Direct X has nothing to do with drivers, it is a set of APIs. If you are running Windows on your Mac, then you can use the Windows drivers for the hardware since it is for the most part identical.
I don't think so :) I heard they use wrappers or some programs to play Win games on Os X, applications taken with torrents !
