Install Win xp on Leopard and Mac Air!
Iulian81
Hi! I have an Macbook Air and I want to install win xp using Leopard and the BootCamp utility. The problem is I don't have a network with another PCs from witch I can use an optical drive and an winxp disk. How else can be installed Winxp on this kind of computer?
On a 2008 Mac Air it is possible to boot from USB memory stick? And what commands do I must choose? I remember for my old PC is F8 to choose the installation drive and Del to enter BIOS? This Mac has the same features?
I don't know. I know jack about macs. It was just a suggestion.
Anyone you know have an external CD drive you could borrow?
the macs should see the flash drive as another drive and check to see if its bootable. i have seen just about every mac check all its media to see if its bootable. after that im not sure. the only boot loader i ever dealt with is linux
