JohnJSal
Hi everyone. So here's the story. Last night I was finishing up in World of Warcraft and I shut down the game. Usually what happens is when you are in a "resting" area and you click "Exit Game," the screen sort of locks up for a few seconds as it shuts down and then it just goes away and brings me back to the desktop.
Well, this time I clicked "Exit Game," the screen froze as usual, but instead of closing down the game, the game remained frozen on the screen and a bunch of horizontal (somewhat jagged) red lines appeared all across the screen. They seemed to be flashing somewhat (in a very quick, tight way, as if they were moving around within a very small space).
I tried Ctrl+Alt+Del, Alt+F4, Esc, Alt+Tab, but nothing had any effect, so eventually I just reset the computer. But the problem persisted even after the reboot. During the boot up screens (the DOS-like screens) there were still jagged lines across the screen (not red this time, but visible in that they were interfering with all the text on the screen).
I got a notice saying Windows didn't shut down properly, so I chose to boot into Safe Mode and see what happened. It booted up but the graphical issue remained on the screen.
So I reset again and booted normally. This time I got as far as the progress bar showing that Windows was loading, but then the entire screen was taken up by waving lines (yellowish, maybe some color, but I don't remember for sure) and I couldn't see anything else on the screen. The screen appeared black except for the lines, but there were so many lines this time (and moving much more noticeable, like wavelengths).
I wasn't sure if Windows had booted up and I just couldn't see it, or if there was actually a problem with the boot itself. I tried the key combos listed above again but nothing happened, so I held down the Power button until the PC shut off.
Right now it stands at that. It's shut off and I can't deal with it until tonight. I'm planning to open it up and blow out the dust, check if all the components are seated properly (especially the GPU), but other than that I don't know what to do and I'm panicking. I've never had a problem with this PC in the two years that I built it, and this particular issue has never happened before in any form.
Given all of this, does anyone have any idea what the issue might be? It seemed very odd to me that it happened *right* at the moment I was shutting down WoW, so I don't know if that had something to do with it, and if so how a single program could affect my screen like that.
I'm also not sure (and really hoping not) that it's the monitor itself that's the problem. During the brief period where the screen goes into an off or power down mode, there is a blue box that appears that says something like "Digital Power Save Mode" and this appeared very clear without any interference, so either the monitor itself is okay, or this particular screen is displayed differently than the other screens with the problem?
Anyway, please, please help me. This is killing me because right now my PC is completely unusable.
Thanks.
Thanks.
