help me! The battery of my laptop HP DV 2000 doesn't work!
cecilia
Hey guys,
I am worried now. What can I continue my lesson without my laptop? Right now, the battery is not working any more! I need ur helps!*
Thanks so much!
Hey guys,
Thanks so much!
If you have tried to charge it, but won't work. Then it might be the charger that's faulty and not your battery. Try to borrow somone elses charger and try. or go to a computer store and ask for a new battery, charger or for help. I can't really see your problem from over here :/
oh, thanks guys so much!
I think I have to change it but I don;t know about kinds of this battery. Who knows, plz help me!
try to calm down and explain everything whats happening with your computer.
you can work on the laptop even if you dont have battery. just connect it to the charger and turn it on. if its not working like this, so it the problem of your charger. try to plug it in other pluger and check if the cable is connected well in the charger.
