bomberboysk
If you are new to building, someone really shouldnt have suggested such a high end motherboard to you, as the only real reason to have a UD7 is if you plan on highly overclocking(and even then, the X58 classy is the better choice).
The Motherboard should be displaying a code on the LED post indicator, tell us what that LED code is.
Also, make sure your EPS12v connector is securely connected.
