I have just built a new computer with a Gigabyte GV-N250-1GI card which uses NVIDIA GEFORCE chipset, which I have a question about.
The motherboard is a new Gigabyte GA-X58A which is using an i7 CPU, 4 gig of memory and has a new Rosewill 650 watt power supply (just FYI, the power supply and CPU were part of a special combo deal at Newegg).
When I start or end windows, I get an error message that the video card is not receiving enough power, and it is running at a lower resolution to save power. It says to attach the additional power supply or check the power source. Well, the card's manufacturer says it needs a 450 watt power supply or greater, which I definitely have. I have no idea what the "additional power supply" might be since the card is firmly mounted in the board, it is working normally, and there is nothing I can find in the installation instructions indicating another power source that can be attached anywhere to the card.
First, from what I can tell, there are no issues setting the card to any resolution/frequency combination that I want. Also, the picture I get is excellent, and since I don't do any heavy duty gaming, I'm not sure I need to change anything.
The power supply connections to the motherboard are all connected and seem to be firmly seated. I would think that if something was wrong with a connection there, nothing would work at all.
What else could this be referring to, and how do I fix it???
Thanks.
SMK
Thanks.
SMK
