new water cooling loops!!
funkysnair
well its the time of year to upgrade the water cooling!
i was going to do dual loop but instead ive opted for a single loop with 2 pumps and 2 tripple rads in series
my plan is to put a tripple rad in the roof of my coolermaster cosmos sport and a tripple in the front (which i know i can do as case is modified)
now i have some of the parts now but im still waiting on a few
i have
all to fit inside my sexy painted cosmos
i have still to come
another d5 pump (from pies on cf)
another tripple rad
some black tubing
compression fittings
thermal pads for gpu block
liquid
3x noctuas fans
This system really help the person whose PC get hot during some small time of period. I am sure you will share some more developing technology.
just ordered
Nanoxia Speedflow Ready Fluid x2
Masterkleer 7/16" Tubing Black x4 meters
compression fitting G1/4 - compact - black nickel x10
Phobya Thermalpad Ultra 5W/mk 15x15x5mm x5
i am well on the road to being skint
watching another 5850 on ebay, finger crossed i get that sucker too ;)
yes i did, but the internals are acrylic unless the water is just supposed to leak from the hole in the front?
Didnt realize the internals were acrylic;)
just ordered
Agree with noob here, distilled water is gonna give you better temps and be cheaper.
more goodness
Black Ice GT Stealth 360 XFlow Radiator
Scythe Kaze Jyuni 1200RPM Slipstream 120mm Fan x3
couple more of these
couple of pictures of the process
my 5850 getting attention (like it deserves)
my beloved componants sitting waiting to get back in
black ice 360 rad up top
black ice rad in front (weird pic of the noctua)
both rads with fans,mobo and res installed
then this is it up to now, i still have cable management to do and a little clean up but it still looks good
TEMPS ARE
gpu powercolour ati 5850 @850/1200-1.162volts 24c (idle)
cpu intel i7 [email protected] volts 34c (idle)
motherboard 33c (idle)
I bet its virtualy silent now eh?
I wish watercooling kits wasnt so expensive,Or i would have a go myself :cool:
Btw your monitor looks very similar to the 22" 1080P TVi just brought :)
yeh its not far off silent, thats with the side panels off too
this kit set me back £400ish, i havent added all the figures yet and i dont think i want to incase i frighten myself!
just got my second 5850+water block and second intel ssd to buy
the samsung monitor is 22" 1680x1050, brilliant picture quality-lloking at getting a samsung 1080p monitor soon-or another 2 of these
looks good man. keep up the good work.
thanx
Hm... advice? Buy me something.
Have you thought of upgrading to two completely separate loops in the future? All that's really holding you back is a res... Because right now... that pump is just floating there.
nah, i think the setup i have now runs some good temps-the res cost me £60 so im in no hurry to buy another
i added the second pump as the mobo block is restrictive and so is the cpu block, im not sure a single d5 would last as long as there designed for!!!
oh and i aint buying you anything lol, i would love to run seperate loops eventualy but i dont think there would be much temp advantage to warant the extra costs
