Will the 5770 work with my current system?
Respital
The minimum power requirement is 450w, my PSU (see sig), is 500w so I'd say it's hitting a bit close but the requirements for two is 550w or so, and i really doubt that it's actually going to use that much. So what do you think?
XFX 5770
The 450w requirement is for the entire system. With 500w you should be fine... jsut don't try crossfire ;)
Don't sweat it, a 500w Antec will handle it easily. I've heard of somebody running one on a 400ish watt generic brand once (although that probably wasn't a good idea.) Either way, Antec being the quality brand they are, will DEFINITELY handle that card. :good:
