funkysnair
or buy them off overclockers and have them posted through your door royal asse mail in 2 days like i did
for me, when i do something like that i would buy some shin-etsu paste, alcohol wipes and new pads---
clean everthing out with compressed air 1st (after taking it apart) clean all the excess paste off with cloth pull all pads off then clean all the point of contacts with alcohol wipe apply shin-etsu to gpu core apply new pads to areas of contact then put back together
obviously thats for optimal results!
i dont see the half arsed job working as good as the full effort job, just my opinion
Forgot to mention i did use Akasa Heatsink cleaner on it too which is Citrus based solvent....probably nowhere near as good as Articlean but it seemed to have cleaned it up nice...and made it smell nice
Idle at 40c atm with 65%.
Gpu-900Mhz
mem -1000
Thermal pads have resiliency built into them for such purposes, thermal paste on the other hand has to be reapplied each time. As far as cleaning the gpu, i prefer arcticlean to alcohol, works quite alot better. Shin etsu is definately the way to go for anything though(well, barring subzero stuff, ceramique is where it's at for that).
but can you tell me that used thermal pad is the same as new?
if you cant say 100% that thermal pads thats been used for months is going to perform the same as brandnew pads then for £2 a strip i would invest in new pads!!
im sure you cant, so thats why i replaced mine...
also the cleaner i used was isopropyl alcohol (99% pure anhydrous alcohol non aggressive)
£4? i still cant see the logic in saying use the same pads? its like saying dont bother re-applying the thernal paste just get a credit card and scrape it into a pea size shape again and that will do?
obviously a quick fix it will do but for someone worried about there temps i though advising them to clear all dust from heatsink, re-apply thermal paste and thermal pads?
Again, thermal pads and thermal paste are two entirely different mediums. Soft thermal pads are designed to be able to be reused(which is why many laptop manufacturers use them on gpu heatsinks as well) while thermal paste is a one time deal.
i know there textures are different but your saying that thermal pads used are the same as new!
the two gpu's i have just done the thermal pads where compressed so much if you held it up to the light you could see a thread like material through it
i would belive that a pad that has had no impressions would make a better contact with the surface?
i would never re-use thermal paste or thermal pads myself especialy considering the price of both
i cant and will not allow it!
maybe its me but i cant see the logic in paying a few £'s for themal paste for gpu and not paying a few more for thermal pads "it makes no sense"
in my opinion its half a job!
i wouldnt do it, i wouldn t advise anybody else to do it especialy considering the price involved
Again...there is abosutely no need to do so. In fact, most gpu's do not even have any cooling on the memory chips, they do not get hot enough to warrant such measures, especially when considering the same exact gap is being filled(unlike with a grease or liquid form of TIM, which flows to the gaps within the thermal contact areas, which must be replaced every time).i cant and will not allow it!
You can re use thermal pads, its not going to make a difference. Buying thermal pads every time you take a card apart or take off a Vreg heatsink\waterblock is asinine. You might as well just eat the money instead.
besides, you dont have to replace thermal paste every time you take a card apart, take off a heatsink\etc.
