robertbiferi
banned
I use CCleaner and I need some help.
I click on the Registry Cleaner Tab and then I click on Scan For Problems and it does.
Then it brings up a lit of things to be fixed and I leave everything Selected with a check in the box.
Then I click Fix Selected.
And the next window has two tabs Fix Issue and Fix All I click Fix All.
And it does and all the prablems go off the screen so I close ccleaner and restart the computer.
Now I run it again and it brings up a big list again it never stops I thought I fixed everything.
I can do the same thing over and over and over as many time as I want.
Am I useing it wrong did this happen to anyone els??????????????
How do I use CCleaner??
