Solution to this problem...
This really is an old thread lol,but it seems that many people are having problems with this.So I made you all a small program that actually solves your problem.The program looks like this:
You can download it from here:
http://www.sendspace.com/file/gotmg7
HOW TO USE IT ON WINDOWS STARTUP:
It's so damn simple.
Just extract the downloaded file and then open that extracted folder called "PROCESS KILLER AND PROGRAM STARTER" and in it you will find 4 files.One of them is called "PROCESS KILLER AND PROGRAM STARTER.exe".So now simply copy that file called "PROCESS KILLER AND PROGRAM STARTER" and paste the shortcut in your STARTUP directory.For example:
C:\Documents and Settings\Your User Account Name\Start Menu\Programs\Startup\
This will enable the program to run when the Windows starts up.
HOW TO USE THIS PROGRAM TO DO EVERYTHING AUTOMATICALLY WHEN WINDOWS HAS STARTED UP:
This is even more simple lol.
In the first blank field write the name of the process you want to be terminated when Windows starts up.For example "explorer.exe".In the second field write the full path to the program you want to open.For example:
C:\Program Files\My own program.exe
Also be sure to check the check box below these 2 fields.
Cheers everyone!
