uk tv online when out of uk,, help pls,,,
rob70
hi guys,
does anyone know an online program, server, website or u name it!! ,,,that allows users to watch (FOR free only) uk terrestrial channels whilst the user is out of uk without applying any geo restrictions/block??
Many thanks, nice day all!! :o
You could get a Freeview USB adapter like this to shove in your laptop.
However im not sure what the signal will be like with that Antenna,I had mine connected to a real antenna on the roof.
At maplin :)
http://www.maplin.co.uk/Module.aspx?ModuleNo=221083
I had this exact same one,Infact i still have it in my draw somewhere as i no longer use it as i have a new TV....It worked very well....however the little antenna they supply isnt very good,It gave a weak signal so i connected it to my main antenna on the roof and it was perfect.
Im not saying the one supplied wont work,But it wont be the best :cool:
The antenna on them things are shite :P
Where is the OP going to be located? You'll need to be able to locate Terrestrial channels in wherever the place is that you're going first :good:
thanks,,where do do i buy it, how does it work? u mean with this i can stream freeview into my pc??
This only works if you are in the UK or the coastal regions of France, Britanny etc and then it would have to be a multi element aerial. There is nothing for free that will do what you ask outside of the UK.
