Another question, I'm finally getting around to my new build and have a fitmit issue. I have a CM Storm Scout and my 4870X2 won't fit. I'd have to remove the drive where the HD would go and buy a 5.25 bracket to fit the HD and put it up higher. Does anyone have this case and what did you do to fit your long GPU card. I have the Arctic Cooling Accelero Xtreme on the card to keep it nice and cool. If I took it off, which I won't it would fit snug in there. Any suggestions?
Thanks
Thanks
