ASUS Crosshair III Formula
kyleswitch
Im running an asus 5850 and I was thinking about crossfiring another one with it. I want to get this mobo:
http://www.newegg.com/Product/Produ...131392&cm_re=crosshair-_-13-131-392-_-Product
it says it comes with a sound card, but like hell I'll be able to fit it on the board witht he 2x 5850's. So my question is, do you think i will be able to to fit the sound card on the board with both the cards or would I have to use the built in HDMI audio from the 5850 card?
Anything Im not aware of please let me know.
And is there any reason I couldn't use this board?
http://www.newegg.com/Product/Produ...131644&cm_re=crosshair-_-13-131-644-_-Product
No, I don't think you will be able to add the card. As for the Crosshair IV, I see no reason why you couldn't get it. In fact, I'd get that one instead, for $30, your DDR3 standard is higher, you get another slot for Tri-CF, and newer north/south bridges.
and I wont need a sound car because its mounted on the back :good:
Ill get the crosshair IV then.
Thanks for pointing me in the right direction
