Video card help
ugakid011
Hello, I am trying to have dual monitors on my computer and I just want to make sure I purchase the correct video card so the monitors can be used at the highest resolution possible. I am currently using a 24" Samsung syncmaster 245BW (1920 x 1200) and am connected via VGA - PC. The monitor I am going to purchase is a 20" 2007fp Dell (http://accessories.us.dell.com/sna/...etail.aspx?c=us&l=en&s=dhs&cs=19&sku=320-4687). I want to be able to run this monitor at 1600 x 1200. The main reason I want this monitor is so that I can rotate it 90 degrees and use it in portrait mode. Below I have listed the specs of my computer which might be useful to those who can help (:confused: not me) If anyone can provide me with any help at all I would be very grateful. Thanks everyone!
Power Supply 450 Watt -- Standard Power Supply-
Motherboard [SLI] ASUS P5N-D -- NVIDIA nForce 750i Chipset w/ Raid, 2 PCI-E 2.0 x16 MB-
Video Card Brand === High Performance === EVGA Brand Video Card Powered by NVIDIA-
Video Card NVIDIA GeForce 8500GT 512MB w/DVI + TV Out Video-
Memory 2 GB [1 GB X2] DDR2-800 PC6400 Memory Module-Corsair-Value or Major Brand
Anyone? I just want to make sure that the card I buy will allow the monitors to work at max resolution. I also don't know if the size of the power supply will be an issue. If anyone can help me out I would be very grateful!
You have a 1080p HD monitor - and running through VGA. You could get a much better picture out of that monitor if you used the DVI from your PC.
I'm far from an expert - so take it with a grain of salt - but I'm pretty sure your Monitor and drivers associated with it - determine what Resolution you can run on your Monitor - rather than your video card.
I think Your video card will give you lower performance at higher resolutions - ( FPS in Gaming ) - so that's the only limitation I'd think of.
I'd let others weigh in before putting your money down for a purchase though - as I'm still learning myself:D.
Thank you for your response Jamin23! Can anyone out there confirm what he posted please? I can spend around $90-150 on the video card, so if anyone has any suggestions I would appreciate them.
Digital-based standard designed for displays such as flat-panel displays LCDs, plasma screens, wide high-definition television displays and video projectors.
