Hi,
I have notice I had problems starting linux from the GRUB menu. It just went black and nothing happened. I pressed E in the GRUB menu to edit the entry and have found this line:
I have figured that the problem was the QUIET_SPLASH and deleted the words. Then pressed keys to boot and it worked.
The problem is, I HAVE TO DO IT ALL THE TIME ..
I would just love to edit the /boot/grub/grub.cfg file but it won't let me save the changes (even as root), as this file gets automatically generated.
I have found nothing in /etc/grub.d files and nothing in /etc/default/grub which could lead to disabling this QUIET SPLASH option.
Can anyone tell me how to do it? Or maybe there is a command to update changes in the GRUB command line itself?
Would apreciate your help as this is quite annoying.
PS. as far as I remember there used to be a MENU.LST in grub? what happened to that?
Code:
linux /boot/vmlinuz-2.6.31-14-generic root=UUID=26656dae-ecc1-44a0-8872-edfbed7f81af ro quiet splash
