durkmusic
I've been running 2X2GB DDR3 at all auto settings (has been running around 669MHz)for a week and it has been fine. The RAM says that it is made for 1600MHz 1.65V 9-9-9-24. So, I go into the BIOS and change the frequency to 800MHz and the Voltage setting to 1.65V. When I use speccy to monitor my computer settings, it shows me this:
4.0GB Dual-Channel DDR3 @ 803MHz 11-11-11-29
Shouldn't that last part be reading 9-9-9-24?
Would I be able to set it to 9-9-9-24 in AMD Overdrive?
Also, speccy says this:
Type DDR3
Size 2048 MBytes
Manufacturer Corsair
Max bandwidth PC3-10700H (667 MHz)
Part number CMX4GX3M2A1600C9
SPD Ext. EPP
Notice the max bandwidth. It says 1600MHz on the stick of ram but in speccy it says a max bandwidth of 667MHz which would be 1333?? Is this correct or is speccy lying?
Thanks.
Type DDR3
Size 2048 MBytes
SPD Ext. EPP
Thanks.
