firefox slow to start up with win 7 pro
tremmor
Well-Known Member
Any ideas?
its a quad core. 4 gig and ya double click it then takes 30sec to start.
all the other proggys start fine. defrag and cleaned up.
still same thing. programs like thunderbird and everything else starts fine.
thanks
whats funny is ive rebooted and everything.
the 2nd, 3rd and all the others is same results.
its all the time.
Disable/uninstall add-ons that you are not using. It will definitely improve your Firefox performance.
that did it. i startedd checking some of these addons i had. i had some addons installed for hp printer. i was running some software from hp and forgot to uninstall.
thanks
its fixed. works fine. its the latest edition.
i suspect some programs or what ever was just hogging resources.
i cleaned it up (the computer). uninstalled programs i suspect may have
been a factor.
