need help on making my compute wireless
alex10
hi, i need some help on making my computer wireless as i have just got my new pc (Dell xps 625) and want to start gaming and dont no of any way of doing it to get good fast internet to it if any one can help i will be most grate full :)
i don't see ya doing much gaming with a wireless connection unless your playing checkers, chess or something.
get a cat5 cable.
Wireless or Copper?
LAN is recommended for gaming and networking. you can only use wireless if you have a strong signal where you stay, but wireless signals can be easily tempered with and it cannot cache half of the graphics you need. wireless is not an option for a gamer, so its a no from me.
To make the computer wireless you will need to have either a PCMCIA wireless card or a USB Wireless Adapter attached to the computer. Then your modem will need to be a wireless router modem. This way you can start to have a computer being wireless connected. The Ethernet Card is for you to plug the RJ45 to the port of the modem or a wireless router modem. So it will be a wired connection and not a wireless. therefore you will need the above mentioned item to start to configure for a wireless network.
hi thanks for the help, Would i be able to run the cable out side of my house so that i dont have to rip the floor up to run the cable up my stairs
DSL internet connection can run via your phone line - and your local Cable Company probably offers Cable internet as part of their services. So if you can get Cable TV - you should be able to get Cable internet.
Yeah get yourself a box of CAT5 and run the wire outside round from the router to your room then back in through the wall to the computer.
Be fine.
Catherine
