I have no clue how to build a computer
mixon
OK...so I need to build a new computer because my desktop is a dinosaur (dell dimension 1100 or something) and my laptop isn't really meant for gaming.
I'm looking to build a computer that can run starcraft 2 at decent settings.
If I'm looking to spend 700-800 on building a PC, what should i dedicate to each thing? I don't want to get stuck buying a couple of nice things with other crap components.
I already have keyboard, mouse, monitor and an OS
thanks
Phenom II x4 955 + 5770 combo
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.383421
Or
Phenom II x4 955 + 5830 combo
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.383393
ASUS M4A88TD-M AM3
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131649
A-DATA Gaming Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model AX3U1600GB2G9-2G
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211409
Sony Optiarc 24X DVD/CD Rewritable Drive Black SATA Model AD-7240S-0B - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118030
Antec BP550 Plus 550W Continuous Power ATX12V V2.2 Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371016
NZXT BETA EVO Classic Series CS-NT-BETA-EVO Black Steel / Plastic ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146059
You may need some extra case fans ...
http://www.newegg.com/Product/Produ...n=120mm fan&bop=And&Order=RATING&PageSize=100
^ Google is actually fairly bad for learning about new components, and which ones to buy. You frequently end up with guides that are a year or more old, which is bad because new computer parts come out monthly.
Just use this guide. I did when I built my first computer. Spend some time on this forum posting parts in one thread and see what people think. I spent 6 months on this forum researching before I actually built one ( you dont have to, i just wanted to get my money's worth).
Making sure parts are compatible is the big thing, then swap things out for better performance/price.
Everything in my signature (put together) doesnt go over $800 I think, you could even get a 5770 gpu instead of the one I have and it will be about $700.
Use Newegg.com for parts. Best place to order from. Reading reviews is important as well!
Okay, check this out. With tax and shipping this comes out to $800 even (that's not including $35 in mail in rebates). The cpu is a quad core, that thing is beast and will last you years. The Mobo is an AM3 socket, future proof, so if you wanted to upgrade to a 6 core cpu later, you can. The graphics card runs any games today at great settings, even maxed out with great frame rates. The graphics card supports dx11, the future in gaming graphics. Every part has great reviews.
CPU, Motherboard and Graphics card: http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.381162
Power Supply and Ram: http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.394532
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119161
Hard Drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
CD Burner: http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
So again, this computer is good for the next few years and even then you can overclock to make it last longer. And yes, it can play Starcraft 2 and blow it away.
If there is an issue with the parts/price let me known and ill adjust some things. But, this is everything you would need to order and you will be all set.
