So you're talking about a Radeon 9000, right? Try making sure that it's bottomed out in the pci slot. When it slides all the way in, you can tell. I've had a similar problem with a Radeon 7000 before.I just got an ati r9000. I've tried every pci slot and the PC doen't recognise it. When i tried to install the driver from the disk it says that the hardware isn't there. Any suggestions??![]()
Well, when you try to boot with the card in does it display off of its VGA port?I've tried reseating it in three different ports. Could it be a bad card?
